Dell Insprion N5010 No Display Continues 3 beep sound DG15 AMD
WHAT CAN I DO ANY 1 HELP NEED URGRNTLY
THANK U
Dell Insprion N5010 No Display Continues 7 beep sound dg15 amd
arunbharti
Re: Dell Insprion N5010 No Display Continues 7 beep sound dg15 amd
Check image
- Dell beep codes.png (18.41 KiB) Viewed 7013 times
just check any smd burn near chipst
otherwise reblow the amd chip problem solved
anandvsalunke
Hi,
Do a systematic check first.
Disconnect LVDS connector from motherboard and see if you get display on external monitor. If yes, then most probably, you have bad graphics chip, which is most common is this model. Check whether you get enable singals for LCDVDD supply, which is generated by graphics chip. If you have bad graphics chip, you may consider doing UMA conversion to Intel HD graphics.
All the best.
All the best.
dnyaneshwar1
