Dell Insprion N5010 No Display Continues 7 beep sound dg15 amd
arunbharti
Post by arunbharti »
Dell Insprion N5010 No Display Continues 3 beep sound DG15 AMD
WHAT CAN I DO ANY 1 HELP NEED URGRNTLY
THANK U
Domas
Admin
Admin
Re: Dell Insprion N5010 No Display Continues 7 beep sound dg15 amd
Post by Domas »
Check image
Dell beep codes.png (18.41 KiB) Viewed 7015 times
manikodai
Post by manikodai »
just check any smd burn near chipst
otherwise reblow the amd chip problem solved
anandvsalunke
Post by anandvsalunke »
Hi,
Do a systematic check first.
Disconnect LVDS connector from motherboard and see if you get display on external monitor. If yes, then most probably, you have bad graphics chip, which is most common is this model. Check whether you get enable singals for LCDVDD supply, which is generated by graphics chip. If you have bad graphics chip, you may consider doing UMA conversion to Intel HD graphics.
All the best.
dnyaneshwar1
Post by dnyaneshwar1 »
good sir
