cq 40 power on white display issue
board lal50-la4101p
dignosis
checked in external display ok but internal white display coming
checked with new lcd with cable but same issue
then checked in lvds conector
found 18v ok
but lcdvdd not present pin 7,9,11
which is coming from q7 transitor of pin 1
q7 pin 3 have 3.3vs and pin1 have no volage which is called lcdvdd voltage
lcdvdd voltage is missing
resulation
chane the q7 transitor and checked display working fine
cq 40 power on but white display issue
Re: cq 40 power on but white display issue
i had a same problem solved it in same way
Yes same way
Nice job
[ Post made via iPhone ]
servis jaya
Goog Info...Thanks Master..skbasir wrote:cq 40 power on white display issue
board lal50-la4101p
dignosis
found 18v ok
resulation
vishalhegade
Samsung r507 laptop white screen problem
vishalhegade
