MODEL MS-7525 VER:1.0
PROBLEM NO DISPLAY
DEBUG ERROR CODE 0B0B
RAM SOUND BEEP COMING AFTER THIS ERROR SHOW
BIOS FLASH AFETR SAME PROBLEM
PLZ HELP
ms-7525 display problem
1.Board model/number
2.Describe problem clearly
3.What you did to solve problem
Re: ms-7525 display problem
try changing ur ram or flash another bios sometimes bios is not matched the ic
i am change the bios ok m/b but same
softlink computers
Dry solder the ram slot at the back side of the board.
alexasha8311
reflow north bridge
wash board and reflow some time ...
change the clock this is smbus & smclck filure
