m5030 nodisplya
ihrasameen
m5030 nodisplya
Post by ihrasameen »
when the adapter is connetcted the lap will switch on auto maticly but no display all voltag ok. bios re progeamed same status. i need a help
Domas
Admin
Admin
Re: m5030 nodisplya
Post by Domas »
Re: m5030 nodisplya
check all voltages the ACIN goes through it
and also check voltage like
3.3v alw and 5 alw and also Ic controller for these two voltages
rajnish
Re: m5030 nodisplya
Post by rajnish »
if your laptop AMD check all voltages
than you check processor
next you check AMD chip
avdesh1
Re: m5030 nodisplya
Post by avdesh1 »
please share beep codes as dell laptop
by the motherboard if 8 beeps go for igp chip else on 7 go 4 cpu
rajeshkumar45
Re: m5030 nodisplya
Post by rajeshkumar45 »
SHARE UR MOTHERBOARD PART NUMBER WHEN WE SOLVE UR PROBLEM PERFECTLY
Re: m5030 nodisplya
you can replace AMD chipset not succes reballing
avdesh1
Re: m5030 nodisplya
Post by avdesh1 »
chip replacement never be a option first search a question why problem priests then go solution
u having dell pcb its debug codes and debug system soo inhance use it
