HI All Master....I have a problem Asus A43T..keyboard not working after laptop booting..
but in BIOS keyboard work normally...after booting become not work..with USB keyb also not work..(USB port All cek normally in bios,keyboard also work normall)
__Flash bios stiil not working..
__Kode mainboard =LA-7551P
Help me solution....Thanks...
Asus A43T Keyb not function
amit sharma
Re: Asus A43T Keyb not function
Use Hirenboot After Your Keyboard Working Then Reinstall Windows
But
Your Keyboard Not Working In Hiren
First update bios
Second check pf or resistance for working near keyboard connctor
Last Change I/O
But
First update bios
Last Change I/O
- arisravi1968
remove small brown capacitors connected to keyboard connector before replacing i/o
servis jaya
Oke Thank All Master for your informations...i will ceck it...
Thanks..
Thanks..
