in this lap no ac detect led didn't glow(led near dc jack) 3v 5v ok charging volt ok vrm hv19 ok but no power on
where i start troubleshoot pls give me suggestions
compaq presario cq42-116tu
ganeshcell
Re: compaq presario cq42-116tu
Flash bios
mcplslg123
Might be ene kbc problem. Check pin#106 of kbc. You should get 3v here for dc jack to glow. If it is around 1.5 then verly likely kbc issue
You need to flash the bios
satish panchal
put pd15 new ...near c64 ....sure done
