Cq 40 la-4101p charging problem
shlnarang
Post by shlnarang »
Motherboard - la-4101p
Problem - Laptop shows plugged in charging but battery voltage not increasing it remains same
I have changed battery,charging ic bq24740,mosfets of charging section,programmed bios no success please help !!
Here are the measurements of charging ic
On battery
CHGEN 0
ACN 19.6
ACP 19.6
ACDET 2.2
ACSET 1.2
IADSLP 0
VREF 3.3
VADC 3.3
VADJ 1.4
IADAPT 0
SRSET 1.4
BAT 10.9
SRN 10.9
SRP 10.9
CELLS 1.07
LODRV 0
REGN 5.9
PH 10.9
HIDRV 10.9
BTST 15.6
PVCC 19.6
shlnarang
Re: Cq 40 la-4101p charging problem
Post by shlnarang »
On Adapter
CHGEN 3.3
ACN 19.6
ACP 19.6
ACDET 0
ACSET 1.2
IADSLP 0
VREF 0
VADC 3.3
VADJ 1.4
IADAPT 0
SRSET 0
BAT 0
SRN 0
SRP 0
CELLS 0
LODRV 0
REGN 0
PH 0
HIDRV 0
BTST 0
PVCC 19.6
Post by Arun.shspl »
acdet should according to the charging chip plz ensure and check
shlnarang
Post by shlnarang »
Sir i could'nd get
shlnarang
Post by shlnarang »
Please explain a bit more
sachin03323
Post by sachin03323 »
have you checked PR137 & PR138 resistance value. These voltage dividor resistors feed ACDET pin & u will get around 2.75v on ACDET pin according to the board schematic.
amit sharma
Post by amit sharma »
Volt in p chanel mosfet foulty
shlnarang
Post by shlnarang »
Changed the mosfets 3 pchannel , 2 n channel !! No success
sir frist change io charging coil ...
