Part no DA0KH1MB6E0
problem is no display when i press the power button the caps lock numlock or scroll lock led glowing at the time for 5 to 10 sec then turn the motherboard off
I also try to program the bios chip then replace the core ic or check all volt are available ...
Plz help me to fix the issue plz plz
If its not possible to graphic mode plz help to non graphic the motherboard
[ Post made via iPhone ]
