Hi
i have this board from the above model , part number is 6-71-w24h0-d02a
it powers on but there is no backlight
i need schematic to see what voltage is missing from led screen connector
i check for fuse but there is no fuse near the connector
Clevo W7535 no backlight
Re: Clevo W7535 no backlight
remove the screen and check voltages on screen pcb ( vled, pwm and bl_on ) if you dont have schematic..!!
Back lit require generally 19Volts, Blon(Backliton) 3volts,PWM inverter again 3Volts. please check on screen pcb if do not have the schematics of laptop PCB.
