Case study Quanta R62
No Power
Found pu9 burned and vin track at pin 1 melt and short with inner ground layer, remove pu9, cut vin track from pin 1 and clear shorting with ground then fix new NB670 IC and make jumper from pin1 to pc207. Case done laptop working fine
HP 15-e019TX No power
- 3.jpg (35.76 KiB) Viewed 2694 times
- 2.jpg (31.08 KiB) Viewed 2694 times
perfectwargear
Re: HP 15-e019TX No power
Thank you for sharing
