WHICH TIME WE ARE USE CRO OR DSO ?
- ravichouhan
1. HI GUYS ANY TELL ME IN WHICH CASE( FAULT) WE ARE USE CRO AND DSO.? AND HOW TO USE?
gurmeet singh
Re: WHICH TIME WE ARE USE CRO OR DSO ?
Dso is must when laptop not turning on even 3v at pwr btn. U must hv to check wave fourm at 32.768 khz cristal .
U will find diffrent wave form at both pins pins of rtc cristal and check sus_clk ,, it is a fullswing square wave of same 32khz will indecate u fine working conditions of rtcrtc . When powered on mobo u must g48mhz at usb port which is the sure short way to check clock is working or not .
- ravichouhan
thnks gurmmet sir
thank you sir g
usb data pins have 48mhz signal or only one pin sir plz tell
thanks you have good knowledge about motherboard, respect you
- Howardliesk
ok guys thank you.
yes i think that a laptop with i7-8750H, GTX 1050Ti or 1060, 8GB RAM DDR4 2666Mhz is for sure enough for every emulator with best performance, CEMU included, even if i run emulators on my tv fullHD 46", are you agree?
