model - hp board (ms-7561 rev1.0) msi
i/o- w83627dhg
problem- no power on
dignosis-
checked in power switch have no power
checked in i/o pin-61 no voltage ( here need 3.3v stand by for i/o internal logic on)
checked in pin-72 ps on voltage avilable 5v
checked in pin-74 vbat no voltage (here needed 3.3v which is coming from cmos batt)
solution
change the cmos battry also not voltage avil in pin 74 , so trace it found junk in cmos jumpeer, brush it and voltage
avil in pin-74
then checked for stand by voltage in board found u31 is the stand by voltage regulator (ic up7706) but here only
5v no 3.3v
so change this ic and 3.3v is generate and found 3.3v stand by in i/o pin-61 , also voltage coming to on /of panel
now board power on but no display
debug show reset high with 0000 code
change the i/o w83627dhg-a version and power on and display coming
now its done working fine
hp msi ms-7561 no power on resolve
Re: hp msi ms-7561 no power on resolve
Good job
I Learned this lesson,I'll use it
I like this kind of tracing
wow great hob sir ☺☺
sathish.srikara
excellent Description
