RESET SIGNAL
sai
RESET SIGNAL
Post by sai »
FIRST RESET SIGNAL ON COMPUTER CIRCUIT
RSMRST#
When the Power,Bios,Ec are OK, the RSMRST# will go Hi. In the other word,this pin go Low only when the systemreset.If BIOSdata is error,RSMRST# won’t go HI.
When SIO(EC) get +V_RTC
thecrystal will work.
1. RTC have to be oscillating(32.768KHz).
2. RTCRST# have to be high.
3. RSMRST# have to be inactive (high).
4. PWRBTN# have a trigger.
5. LOW_BAT# have to be inactive (high).
If this 5 present, then EC will recieve SLP_S3# / SLP_S5 from ICH/PCH, in the old ICH or some deferent circuirity SLP_S3 and SLP_S5 will generate directly from ICH,or both EC and PCH having this signal also.
When All+V?S/+V? powers are ready, PWR_GOOD will tie to high to turn on CPU powers(+VCCP and +VCC_CORE).
For More Detail On Reset Signal you can visit our New site Blog
For in Simple Hinglish
- RSMRST# (Resume Reset) – Intel & AMD practical guide
https://ezonecare.com/rsmrst-resume-reset-signal/
- RTC_RST signal – working, voltage & testing
https://ezonecare.com/rtc-rst-signal-co...e-testing/
Also if need in English vesion here you can visit
- RSMRST# Signal — Working Principle (Intel, AMD & Apple Silicon)
https://werefix.in/rsmrst-signal-workin ... e-silicon/
- RTCRST# Signal — RTC Reset Working Principle
https://werefix.in/rtcrst-chip-level-re ... et-signal/
please comment if you need for refrence
Re: RESET SIGNAL
Post by prakash pal »
Nice tips sir ji
gssystem14
Re: RESET SIGNAL
Post by gssystem14 »
good info....
Re: RESET SIGNAL
thanks sir
moh. su'ud
Re: RESET SIGNAL
Post by moh. su'ud »
Save Sir
Re: RESET SIGNAL
Post by pdewida897 »
NICE SIR
Re: RESET SIGNAL
Post by ChetanSethi »
good sir
Re: RESET SIGNAL
very good sir g
wajhulla
Re: RESET SIGNAL
Post by wajhulla »
nice job sir g
jonsen
Re: RESET SIGNAL
Post by jonsen »
thanks sir
