AMD
Desktop Motherboard case studies here
hny
AMD
Post by hny »
Case study
AMD M2n68 mb
problem no display
error d5
start chking voltages found vtt 0.5
it must be 0.9 ( ddr2)
it connect with 8 leg ic .. replace ic bt same replace ram regulator bt same replce mosfets filters bt same replace cpu bt same vtt showing 0.5 v now chking for shorting near slots found vtt resistors with gnd showing 04 ohms ... its wrong ..doosre mb me continuty jyada thi then remove all vtt small capacitors bt statis same after hardwork on this mb found one pf short top of cpu finally mb ok
Re: AMD
Post by Arun.shspl »
very good observatios
Return to “PC Practical Experience”
