Toshiba L735 DABU5DMB8e0 - NO display
Re: Toshiba L735 DABU5DMB8e0 - NO display
Tried-same
sir change your bios ic
Changed - same.
Changed EC - same..
Convert to UMA - same..
Will try replace pch
Bad VS good cpu socket tester
iamkamalrandhawa
I am 100% sure this is not repairable now. :p
its pch either cpu socket, Kamal
I think you can check all capacitor and mosfet that drive the power for pch
maybe they are short so the pch temp goes high
alexasha8311
npce795Domas wrote:will try, thanks
any compatible to NPCE791 ?
alexasha8311
HOW TO CONVERT TOSHIBA L735 GRAPHICS TO NON GRAPHICS.Domas wrote:Model: Toshiba L735
Board : DABU5DMB8e0 REV:E
After TOKIN change mobo turns on , current 0.9-1.0A. NO display.
PCH heats up, changed it - same
Flashed both bios - same
Converted DIS -> UMA -same
Where could be problem?
