I have this hp1000 6050A2493101-MB-A02 with no backlight.
I have got all the voltages at the lvds connector, 19v, 3.3v but still no backlight.
Can anyone point me to where I can locate the Backlight enable pin at the back of the LED screen?
Hp 1000 backlight problem
Arun.shspl
Re: Hp 1000 backlight problem
Way One: Download the screen data sheet and check the voltage in accordance.
Way Two: If you have the pdf of motherboard then please check at lvds connector the back lit on signal which may be 3volts high, Lcd Vdd again 3 volts high, 19 volts supply to which being used to illuminate the led.
On the schematic, I see LCD_BKEN which is 3.3v
THANKS BRO.
I still don't have backlight, I don't know where else to look, I was hoping someone can direct me to the backlight signal enable voltage at the back of the LED screen.
So finally I have been able to solve this problem, the fault was from the PCH, PCH_LCD_PWM was not coming out of the PCH but I didn't reflow the PCH, I just connected the 3.3v from LCD_BKEN (pin22) to the Pin21(PCH_LCD_PWM) of the Lvds connector
mohamedsaid
post your screen code and iwill tell you your test point
rajeshkumar45
god job alway in these situation pwm voltage not genetarte by pch
soo disconnect these signal to pch and joint to BKEN OR LVDS 3.3V FOR BEST OPTION
ganeshcell
short pin 5 and 6 in led screen
PUT IMAGE MY FRIENDS...SO ITS EASY FOR EVERYONE
Users browsing this forum: Semrush [Bot] and 10 guests
