Dell 15 3537 La-9982P 19V OK. GPU is getting over heat. Checked Volt at PL701 13V Missing.
13V directly given @ PL701 there is shot in +VGA_CORE Volt area. Replaced 3 Mosfets. Display Ok
Dell 15 3537 No Power
Re: Dell 15 3537 No Power
pl 701 which section coil sir .
Pl701 B+. This Board runs on 13.3V Check Schematic
i have no schematic but thanks u for ...
Good job
If your share the pic of fault area it will good
- pradipwasewal
i don't understand
pls share picture sir
THANKS
Good job
