compaq 420 pulug in not charging
3v/3v/3v/ come on battery conn,
Re: compaq 420 pulug in not charging
Without power plugged in
tell me the voltage at battery connector all pins ...(with battery)
[ Post made via Linux Laptop ]
sir battery positive supply and two 3v/3v. comes at battery connector ..
does the laptop turn on without battery? if ac goes in but battery does not charge then either the battery is faulty or charging ic is faulty usually a maxim , do you have board schematic or part number of the board?
Battery positive voltage is it above 9v or below 9v?
battery positive pin have 7,2 v
Your battery is in deep discharge condition ...kindly change ur battery and check .....minimum charge position must be around 9v
sunil
sunil
ok sir thanks
Users browsing this forum: No registered users and 13 guests
