dell laptop not start with cmos
Dear All i have dell vastro 1550 laptop when i put a cmos battery than laptop not start (on) but remove than start plz help how to slove problem
Re: dell laptop not start with cmos
check rtc section components and shorting also....
ganeshcell
Post by ganeshcell »
i think its not the problem of rtc section.some dell laptops power on when cmos battery is dead or not present.plz check power switch 3.3v supply.follow the track.check if ur laptop shutdown when pressing power switch
Am0rPHiA
Post by Am0rPHiA »
put a good 3.3v battery
Domas
Admin
Admin
Post by Domas »
Rtc section
Arun.shspl
Post by Arun.shspl »
in dell laptop charging ic power ok out put 3 Volts supply is rtc supply please check this line/bus . or directly change charging ic
arunbharti
Post by arunbharti »
Check pwrbtn 3.3 voltage in power button if not come then give pwrbtn voltage to power button from io
thnx all my respected sir
