lenovo l412 auto shutdown
carter
Post by carter »
dear admin,,,
pls help me
i have lenovo l412 laptop pcb no .DA0GC9MBD0 REV:D
switched on laptop it auto shutdown in 1 hour again switched on and its auto shutdown in 1 hour it continue.....
i change same laptop bios dump but still same issue.
fan continue spinning ....
i think its me problem...
i attached here my origenal bios backup file
plz give me with clean me region ...
lenovo l412.rar
(1.19 MiB) Downloaded 594 times
carter
Re: lenovo l412 auto shutdown
Post by carter »
no one doing with me region
shiva0525
Post by shiva0525 »
carter
Post by carter »
hi guru sir ,,,
thanks for sharing
but is it clean me region dump or just backup from other working machine....?
bcoz you dont specify its backup dump or clean me region dump
i have used 3 backup dump from other site but still same issue...
thanks again for quick reply
shiva0525
Post by shiva0525 »
it`s backup dump
carter
Post by carter »
ok thanks
i have used that file auto shutdown problem solved but new problem create
when turn of laptop its stuck on shutdown logo .....
then press swith then offf.....
no worry .....its ok.....
thanks again guru sir/...
carter
Post by carter »
hi guru sir thanks again
your backup file open in fitc to without any error
so i m doing me region and create new file with clean me region and now all problem are solved...
