ACER 5740 (motherboard JV50-CP MB 09285-1M) does not turn on and no display.
When power button is pressed, power leds turn on, exactly after 1 second, they turn off.
I checked all voltages and they seem fine, when power button is pressed. PLTRST is also fine.
Exactly after one second from turn on, it looks that SLP_S3# and SLP_S4# are turned off by PCH causing system off. All powergood signal is OK.
I have downloaded BIOS from ACER website and flashed, but the set still does not turn on. I have also reflowed the PCH HM55, but no luck.
At this point, I guess that I have bad PCH/ CPU.
Can anyone help me to troubleshoot, i would appreciate that before i go for PCH/ CPU change.
