Hello Friends,
Its case study of HP 15-bs542tu with MBD la-e791p which was having only 0.18A after power ON.
The motherboard was cleaned and no sign of corrotion found on mbd. So after checking all the required voltage
I found that EC_RSMRST# supply on pin 100 on KBC kb9022q was not present so I think to replace KBc so I remove KBC and found corrosion
under KBC pin 100 and the track was cut due to corrotion. I make jumper and put the same KBC and ALL done.
Supply on pin 100 also come 3.3v and Laptop is also OK. Everything works perfect.
No display problem solved in LA-E791P due to EC_RSMRST#
Re: No display problem solved in LA-E791P due to EC_RSMRST#
Plz gve 3v 5v ic no. Of this mobo
- harendra4201
send me schematic ( La- E791P )
