board part no. 820-2337-a
i have updating bios then suddenly power cut off ..some time later power came then i power on
its no display ....
i think bios problem...
so need bios file
a1289 no display
- BeJimmieKat
a1289 no display
I am trying an SD card on the display with the examples but I get a card not found error. The SD card is an 8Gbyte card. Is there a limitation on the size of SD card I can use? I have checked the connections to the eleven board I am using and they are all sound and to the correct pins as per the quick start guide. Is there anything else I should check?
