2e540_INSPIRON_n5010_CORE_I5_vga_ROI
jabirjabiii
- 2e540_INSPIRON_n5010_CORE_I5_vga_ROI.zip
- (1.89 MiB) Downloaded 885 times
- myedumails
Re: 2e540_INSPIRON_n5010_CORE_I5_vga_ROI
tnx worked for me
vishalhegade
dell n5010 powear led on and off only
+3v +5v run volt missing
vishalhegade
+3v +5v run volt missing flash both bios but same problem
vishalhegade
psu showing 0.026 amp only any one help me
- myedumails
hi,
my n5010 5v & 3.3 V missing near cap ptc4603 & 02
but when i reprogram the bios i get 5v & 3.3V even display but only for few seconds like once restart or so
again no 5v/3v reprogramming again same result works once or twice
i even replaced 25Q32 with new ic again only once it work
any help will be greatly appricated
PS: i get 3.3v & 5V near PU4601 caps
power on voltage near IO & switch
but no luck of working
- myedumails
Fixed the issue by simultaneously reprogramming Main as well as EC bios
- mansourdiab
Thank you my friend
