Hi friends,
I had a problem on HP Probook 450 G2 Laptop. The charger indicator ( Orange light ) was blink. I checked 19V line and FETs Everything working fine. I replaced the charging IC BQ24736 by BQ24725 ( Checked Datasheet was Same ). But no use its doing the same. I check The DC/DC Converter ( 3V /5V). checked LDO 3V is ok. but on LDO 5V is showing 3.98V and the output coils( 3v/5v ) not showing and voltages. So i try to find the replacement for RT8243AZQW. But i couldn't find and finally i ordered it on ebay. after two days i got free time to check this again. I check all resistors and capacitors around RT8243AZQW chip. Finally i found PR321 ( 499K ) was opened. I replaced it now the laptop working fine.
HP Probook 450 G2 Charger indicator blink
Re: HP Probook 450 G2 Charger indicator blink
charging IC BQ24736 Replaced by BQ24725 both having same pin map data.
PLEASE SIR SEND ME 450 G2 SCHEMATIC
thanks for sharing your experience, very help full
- alaaljumaily
thanks YOU brother
Users browsing this forum: sauravh sahu and 4 guests
