Acer Aspire E1-472G
Model: MS2367
Dimm display problem, no backlight already changed screen same problem, how to fix...
pls help me,,,
no backlight dim display
Vinit bhandari
Re: no backlight dim display
first of all change the cable or screen
if u dnt get solve the problem then check contintiee by meter 19 v fuse or 3 v fuse on screen and then check voltage if no recive voltage on fuse then same chek on motherboard near display jeck
check 19 dimm socket and 3.3 volt
reigneilmax
tnx po sir....god bless u
Users browsing this forum: No registered users and 14 guests
