Brand : ACER
Seri : P166HQL
Symton : WORKING NORMALY AND SHUTDOWN AFTER WARM...sometime dead permanently
Solution : Replace bad elco on skunder SMPS or replace regulator IC TOP258PN
When you found ACER P166HQL the common problem is dead / can't turn on LED indicator off... or shutdown after warm.. you can cek some capasitor on skunder SMPS for 12V & 5V voltage rail filter.. replace bad capasitor. if all capasitor normal you can replace IC SMPS ..usually using TOP258PN series.. This solution can be done also on other brands of LCD/LED monitor.
ACER P166HQL WORKING NORMALY AND SHUTDOWN AFTER WARM
billysukmasyarifudin
Salah Elsayed
Re: ACER P166HQL WORKING NORMALY AND SHUTDOWN AFTER WARM
May LCD lamps is burned or has bad connection need to illusion it
