MBX-269 Clean Me Bios
Sony SVE1512F1RW
Quanta HK5 UMA
DA0HK5MB6F0 REV:F
MBX-269
Clean Me
Sony MBX-269 clan Me BIN.zip
(3.07 MiB) Downloaded 799 times
manuelframos
Re: MBX-269 Clean Me Bios
Post by manuelframos »
Hi, wath i have to do to see the attachment?
vishalhegade
Clean Me Bios
Post by vishalhegade »
How To Fix Bios ME Region Problem
In this How’s to article, I will tell you how to fix Bios ME Region Problem. It might seem difficult, but it is very easy and sophisticated task. All the information related to solving this problem is given below. You will come up with what is ME region problem, how to clean ME region bios and faults that occur in ME region problem.
What Is The ME Region (Management Engine Region) Problem?
One of the major cause of the ME Region problem is that you take the bios from the other laptop and write it on your EEPROM Ic. Or you download the bios from the specific website or somewhere else and programme it to your motherboard. It is because the information of your motherboard’s PCH doesn’t match to the bios that you’ve installed.
How To Clean ME Region Bios?
Now, you can clean ME Region Bios as simple as ABC. Just follow the steps told in the video for better understanding. You can also follow the written steps of how to fix Bios ME region given under the video.
Note: It is to be noted that, if your laptop motherboard has 2 Bios EEPROM Ic i.e, EC and Main, then you will put the main bios file in this software. The ME Region firmware is stored in the main bios file.
How To Fix Bios Me Region:
The steps for how to fix Bios ME Region Problem are as follows:
Step 1: Download intel me/txe injector.
Step 2: Then, download the database (Intel ME firmware).
Step 3: Run intel me/txe injector, it will ask first time to locate a folder where you save (intel me firmware). After you locate the folder, it will take 2 to 15 sec to load (intel me firmware) then it will show the menu.
Step 4: Just click (open bios) and select your desired bios.
Step 5: Click on (save new bios) button, the software will clean ME Region Bios.
That’s it, your problem has been resolved. Now, just reprogram your clean ME Bios Bin.
Faults That Occur In ME Region Problem:
These are the faults and signs that occur in ME Region problem.
1- When you turn on the laptop at first attempt, the laptop will turn on but the display will not come. At the same time turn your laptop off by pressing the power button. Try the second attempt and turn your laptop on, it will show the display now.
2- In the second situation, you will try several attempts to turn your laptop on, but it will not show any display. In the meantime, it shows out the display at your any try and your laptop along with Windows starts running perfectly. But, when you shut it down and starts again, it creates the same problem of not showing the display.
3- Some time fan run at full speed and PCH heats up, whether the display come or not but your laptop turn of within 15 sec to 5 min.
4- When you press the power button, the display comes after 20-60 seconds.
5- In some cases, CPU temperature is always set at 100%.
6- One of the faults is that laptop runs for 30 seconds, 30 minute or 1 hour and sometimes automatically shut down or restart.
7- Sometimes there is Windows OS loading problem.
Downloading Links Of Software And Database:
Here the links for downloading the Intel Easy Clean Me software and database. Just click on the links for downloading them:
https://drive.google.com/file/d/1JGJhNC ... VaULX/view
https://drive.google.com/file/d/1P5iB9q ... 5Cz_2/view
Return to “Sony”
