la-6842p
booting time windows logo appears then shutoff
plz help friends...
toshiba c660 shut off
Re: toshiba c660 shut off
token ic change
without token
amit sharma
Near cpu capasitor change
cpu near cap changed but the same result
- arisravi1968
what is the pch number,check weather cpu is compatible
- sachin03323
do windows start in safe mode
Fnaly Solved the issue, The default bios setting cpu is overlocked, Dynamic mode change to low mode then booting problem solved, thanks friends
pdewida897
goood work
if it is solved by changing cpu mode from dynamic to low mode, the problem will come again...
changing a working NEC TOKIN is must...
If already changed, again change another new one or replacement CAPS 4x330u or 3x440u.
Users browsing this forum: No registered users and 17 guests
