Dell 15 3542(cedar intel mb 13269-1)no power
ganeshcell
Post by ganeshcell »
I have Dell 15 3542(13269-1)no power.
19v ok
3.3v ok
5v ok
No shorts in motherboard.changed io,flashed bios.changed charging ic,regulator ic,vram,ram ic but no result.power switch voltage is ok.
when i press power switch,power led blinks once.plz help
amit sharma
Re: Dell 15 3542(cedar intel mb 13269-1)no power
Post by amit sharma »
Sorting in mb
ganeshcell
Sorry but there is no shorting in mb.which section to check any idea?
Current rating in psu ?
ganeshcell
Only 0.01
amit sharma
Small pf short check in cpu heatshink base remove the base check it or some track cut in motherboard use magnifying glass.
reflow cpu or main chip
