hp15-p202tu continous restating but when remove the ram laptop is running continiously. any body have solution
motherboard part no is DAY11AMB6E0. checked with defferent ram and reprogramed biuos but problem still same
hp15-p202tu continous restart
mahimapatna
Re: hp15-p202tu continous restart
Check for shorting in ram section
mahimapatna
already chked there is no shorting same issue
mahimapatna
without its running but when put the ram restating
I have this same problem before, just flash the bios and everything will be ok
amit sharma
Clean ram slot and reprogram bios other memory and change cmos bettry
