hi everyone.. this was second time.. when I was heat ati gpu for removing. after mainboard does not power on ever. could the ene kb9012? because I don't have to IO programmer.. do you have an idea? sorry for bad english..
np350v5c
LA-8861P
rev: 2.0
ene kb9012
samsung np350v5c dead after heat gpu
Re: samsung np350v5c dead after heat gpu
was it earlier powering up ?
Have you removed the GPU or hut try to heat?
What is the resistance/impedance of GPU supply line.
Clear RTC
yes it was working only graphics driver was not loading
3.3v ok
5v ok
charge ok
3.3v ok on power button
check gpu rams may be balls short circuit but it is not
try new ati 0833000
try without ati 0833000
I have ezp2010 programmer and try another bios file
change eproms from another working v5c mainboard
I think kb9012 ... but I don't want to take the risk to change
3.3v ok
5v ok
charge ok
try new ati 0833000
over heating hone he gpu short
