ASUS P5GC-MX/1333 NO DISPLAY ERROR 0000
Desktop Motherboard case studies here
skbasir
Post by skbasir »
this board have no display... debug code 0000
CHECK ALL VOLTAGE OK BUT CORE VOLTAGE HAVE 0.40V
BUT CORE VOLTAGE SHOULD BE 1.10V
CHECK THE ALL SECTION PREVIOUS ENGGINEER REPLACED I/O, CLOCK IC, CORE IC , CORE PWM IC
THEN I REMOVED JUST 822 RESISTOR NEAR PROCESSOR SOCKET AND CORE PWM IC
CHECKED CORE VOLTAGE OK 1.10V AND BOARD RUNING WITH ALL CODE
NOW DISPLAY COMING
THIS IS ASUS P5GC / AM/PS LIKE THIS BOARD DEFULT ISSUE MANY TIME I FOUND THIS RESISTOR PROBLEM .. REMOVE THIS ONLY BOARD OK
DEBUG CODE 0000 WITH OK RESET BUT NO DISPLAY
CHECKED CORE VOLTAGE .50V (PROBLEM) WIRTHOUT PROPER CORE VOLTAGE CPURESET CANT GENERATE
NOW CORE VOLTAGE OK 1.18V
REMOVE THIS RESISTOR ONLY 822
Return to “PC Practical Experience”
