Sony MBX-266 Non Graphics Final Solution.
st33693
Re: Sony MBX-266 Non Graphics Final Solution.
Post by st33693 »
If your motherboard turns off after 2 to 3 minutes, you forgot to disconnect the pr903 resistor from the circuit. It is right behind the cpu next to the holder. It is drawn with a yellow box around it. Thanks. Sadeq tashayoie.صادق تشیعی
vickey_vip
Post by vickey_vip »
st33693 wrote: ↑Mon Nov 20, 2023 9:09 pm If your motherboard turns off after 2 to 3 minutes, you forgot to disconnect the pr903 resistor from the circuit. It is right behind the cpu next to the holder. It is drawn with a yellow box around it. Thanks. Sadeq tashayoie.صادق تشیعی
I have checked this also check all components 3 times still power off in 1 minute 10 second exactly. Any solution for this
