case study- dell 3521 trun on but display not availeble-
1st chek all supply, but only 3/5 volt ganrate, core supply ram supply not ganrate.
now chang ram regulater ic , then problm solve..........
dell 3521 \ no display
Re: dell 3521 \ no display
good post
plz share pic as soon as possible
pdewida897
GOOD WORK
- skinnyblues
Nice threat
Pics?????
i am having a problem in the same model. my one is giving 7 beeps but no display. VCC_ Core is missing
reflash both bios chips and it should work, 7 beeps means no cpu, if the procesor has no power its a firmware issue since the pwm its drives by i2c bus and it means it doesnt receive the necesary dwords from kb9012, this could be cause and by the ec firmware from kb9012 but 90% of cases reflash those 2 chips to be sure and it should turn on
sir last few days before i faced same problom i reflow CPU and i got display work done sir ji
