DELL VOSTRO 1550
BATTERY NOT CHARGING ADAPTER WATTAGE CANT DETECT
M/B- DV15 HR
CHECKED WITH OTHER BATTERY AND DELL ORIGINAL 65/90W ADAPTER ALSO NOT DETECT THE WATTAGE
PREVIOUS ENGINEER ALREADY CHANGE THE I/O AND ALL AD/BAT MOSFET
SO I AM GOING THOUGH SCHEMATICS FOR ADAPTER PS_ID VOLTAGE AND TRACK
FOUND 2.7 V IN DC JACK PS_ID PIN
CHECKED AND FOUND PS_ID EC VOLTAGE IS OK 3.3V PR3806
SO I AM CONFIRM MAY BE SOME RESISTOR OR TRACK BURN
CHECKED ONE BY ONE AND FOUND PR3807 IN BETWEEN PS_ID AND PSID_EC IS BURN
THIS IS 33OHM SO THAT I JUST JUMPER IT AND GETTING 3.3V IN PS_ID PIN NEAR DC JACK IN
NOW DELL 65W DETECT IN BIOS AND BATTERY ALSO CHARGED PROPERLY
NOW PROBLEM RESOVED AND BOARD WORKING FINE
DELL VOSTRO 1550 NOT DETECT 65W ADAPTER NOT CHARGING ISSUE
Re: DELL VOSTRO 1550 NOT DETECT 65W ADAPTER NOT CHARGING ISSUE
Good job
I faced with this problem and the 33ohm resistor was the cause
jimit patel
deepak9812423104
THANKS MY LAPTOP IS WORKING WITH YOUR HELP SIR
wonderful troubleshooting.
- samanthban
reigneilmax
good job sir....
Users browsing this forum: No registered users and 13 guests
