Need BIOS for ZAP00 LA-302P
3.MAIN or EC bios.
shijithmlalvp
Post by shijithmlalvp »
Need BIOS for ZAP00 LA-302P REV:1.0 (A00) DELL ALIENWARE 13
Re: Need BIOS for ZAP00 LA-302P
please mention the board plate number correctly
its
LA-A302p
any way here is the attached file for you
Good luck
Dell Alienware la-a302p.zip
(4.18 MiB) Downloaded 897 times
shijithmlalvp
thank you
buzyn
Post by buzyn »
Thanks for the dump. I inserted a clean region replaced the Windows key. everything began to run very quickly. but alienfx doesn't work. On the motherboard there is still flash memory with a smaller volume. maybe you have a dump from it.
I think this is where the address is stored to manage Alienfx
buzyn
Post by buzyn »
here is a clean region. you just have to drive in your Windows code
Alienware13 HEX clear region winXXXX.rar
(3.92 MiB) Downloaded 786 times
ibrahim
Post by ibrahim »
thank you for sharing
Return to “Ask BIOS here!”
