problem--- no power on dead
LAPTOP --- C700
BOARD PART -- LA-4031P
first look before dignosis
at dc jack light glow when put adapter
means step down section aproxly ok alw voltage ok
suspected first look bios issue
dignosis
checked the board found 3.3v & 5v ok
checked in power switch also 3.3v ok
when press power switch no diflect in load amp that is .20amp
checked the bios chip in pin 8 have always 3.3v ok
checked the bios chip pin no 1 have no voltage means bios corrupt or SIO issue
checked once again after brush the bios with ok bin also have no voltage in bios chip pin 1
bios chip pin 1 conected to sio pin no 128 via one resister R345 (0 OHMS)
checked that resister track cuted so joint that track with resister also same issue no volt in bios pin1
bios pin 1 is FSEL# SIGNAL which is genetare from sio by through pin128
at this time once saw SIO crystal aslo damaged
changed the sio Crytal 32.7 and checked also no voltage in pin 1 of bios
checked the NBSWON SIGNAL ALSO OK 3.3V also acin/acok voltage is also ok 3.3v
checked the onoffbtn# voltage also ok 3.3v
checked the EC_ON on sio pin 102 is missing
EC_ON is generated through SIO IC
SO suspected sio issue
resolution
change the sio ENE KB926QF B1 WITH NEW ONE AND CHECKED THE EC_ON ON PIN 102 OF SIO OK
ALSO 3V OK IN PIN 1 IN BIOS CHIP AS FSEL# SIGNAL
NOW PRESS THE POWER BTN AND BOOM
LAPTOP POWER ON AND DISPLAY OK
COMPAQ C700 DEAD NO POWER ON
- c700 DEAD CASE.rar
- (9.23 MiB) Downloaded 785 times
Re: COMPAQ C700 DEAD NO POWER ON
great
- samanthban
Thanks..
ganeshcell
great ha ha ha
nice one sir
great sir g
very good thankyou
[ Post made via Linux Laptop ]
